Rbs Business Services Private Limited
Posted: Mar 26, 2017
Last activity: Apr 5, 2017
Last activity: 5 Apr 2017 2:15 EDT
Pega robotic management console private server requirements
Hi
I am looking to procure a new server to install open span 8.0 with management console for 100 bots. Can somebody recommend the server configuration for the same.
***3/27/17-edited by Moderator, Maryrita: moved to Product Support from Lead System Architect***
Robots for use with the Robotics Console run on virtual machines, one per robot and the Robotics Console needs an instance of Pega 7. Is that what you are referring to by the management console or are you referring to the Pega Robotics Automation Deployment Portal? To give you a recommendation a little more information is required.
