PEGA Recommendation's For Upgrading To Pega 84x From Pega 827
PEGA Recommendation's For Upgrading To Pega 84x From Pega 827.
We wanted to know the PEGA recommendation's for Upgrade project (Upgrading from Pega 827 To Pega 841) when we have active development is going on.
1. Whether skimming should be done by which team?
2. When the code should be retrofitted ? Dev & Upgrade team's code base?
3. Until the code is retrofitted/merge happens, will the upgrade changes should be part of branches? Could you please suggest the best approach?
***Edited by Moderator Marissa to update Support Case Details: SR-88132***
Hi @appalap9!
Looks like one of your colleagues wrote a similar post that had a reply on it today "On Premise Upgrade checklist from Pega 8.2.5 to Pega 8.4.x". One of our Upgrade SMEs has replied.
Do any of the links provided there answer your questions?
Thanks!
Marissa | Senior Moderator | Pega Collaboration Center
