Pega Platform 8.2.1 - Import application hanging
I put in a support request a while back regarding very slow application import speed and was referred to the article noted below which basically said to change the isolation level in the db to READ_COMMITTED_SNAPSHOT. I tried doing so by running the query in MSSQL:
ALTER DATABASE <DB NAME> SET READ_COMMITTED_SNAPSHOT ON;
The query never finished executing, I let it run for 2 days but it would never successfully execute the query. I created an empty test DB and ran the same command and it instantly executed the query.
I then tried running:
ALTER DATABASE <DB NAME> SET ALLOW_SNAPSHOT_ISOLATION ON;
executed successfully within a few minutes. Tried altering the DB again to read_committed_snapshot and again it just hung.
The application I am trying to upload it only 250MB, last time I tried importing it said it would take over 200 hours to import.
I tried again today and same thing. Not sure what is going on. Attached are the PegaRules log. Any help is greatly appreciated.
