Pega PE 8.3 Installation Error
I have the same issue with installing the Pega PE 8.3.
I get close to the end of the installtion and get ..
BUILD FAILED
C:\Pega\pegaGuiInstallerTemp\build.xml:279: java.io.FileNotFoundException: C:\Pega\pegaGuiInstallerTemp\CreatePegaShortCut.vbs (Access is denied)
I do have JRE_HOME and Path set (see attachment)
I also run the installer as Administrator.
Please help.. :)
