Pega Marketing 7.3.1 Campaign fails but less to see in the logs
When a campaign fails most of the times this cannot be seen in the pegarules.log but only in the Marketing portal itself.
By example, when a larger amount is characters is set into a database fiels the campaign failes with an SQL error, but this is not visible in the pegarules.log.
How to set the config the way it does write those records to the pegarules.log
Kind regards,
Arjan Maus
