Pega Application as Service (Rest API)
I am building a new rest Service using Pega 7.1.7. Was able to create a new instance of Service Rest. Provided in the Post Method, I am unable to map to any Property types(Either Page list or Property list).
No Matter I create a new property or change the map to Clipboard with Corresponding Map to key as String or Data Page would always return the same Error in RED as in the header of the page.
Are you able to assist with this?
that is strange, if you create a simple string type property foo and enter .foo in the MapTo field, it still does not work?
