Pega 8.5 Customer Service Deprecated Rule CPMIsTabbedNavigation
CPMIsTabbedNavigation is withdrawn in Pega 8.5 Customer Service. What is the alternative for this?
***Edited by Moderator: Bhavana S to add capability tag***
@SamT169 If I am recalling correctly, this rule was used to display either the tabbed portal or the 'classic nav' portal - both of which were deprecated in 7.1 versions and desupported in 7.2. There is no replacement since TabbedNavigation (or Classic Nav) is not an option in the Interaction Portal.
Support Doc
