Tata Consultancy Services Limited
Last activity: 19 Sep 2017 14:06 EDT
Pega 7.3 - What is the default ARIA role for dynamic container? Article says "main". System sets it to "presentation".
Default ARIA role for dynamic container is given as "main" in below article. But when I add a dynamic container to a section, the default ARIA role set is "presentation". Is the article correct or the system behavior?
I ask this because, the screen layout's center panel's ARIA role is "main". Since most of the times, the section with dynamic container will sit in the center panel of the screen layout, can we assume assistive technology would navigate to dynamic container for "main"?
https://docs-previous.pega.com/screen-layout-and-dynamic-container-wai-aria-accessibility-roles
