Atos Syntel
System Settings vs Dynamic System Settings
Facts from link https://docs-previous.pega.com/understanding-system-settings-v51
- DSS can be updated/created programmatically, whereas you need to manually update System settings if you want to change it's value.
- System Settings is a rule which means multiple instances can exist by ruleset versioning, whereas only one instance of DSS can exist.
- System Settings can have environment specific value(by use of production level) whereas DSS can have only one value for all(unless you change it in each environment).
Questions
- Can a setting be configured in both System settings and DSS (not at the same time)?
- How does PRPC process/checks the Systems settings and DSS ?
like for example if PRPC needs to check a setting's value, will it know whether the settings belong to Systems settings or DSS or will it check both Systems settings and DSS to find the setting's value.
