Commonwealth Bank of Australia
Pega 7.3 Cassandra Setup - Configuring D-Nodes without UI
Greetings,
So I'm in the process of setting up a 7.3 cluster which will contain 3 separate nodes to be allocated for Cassandra. We will be using the Internal Cassandra integration to achieve this.
I understand that once activated via the UI, Cassandra as a process starts on the D-Nodes and goes through a bootstrap process whereby it reads a cassandra.yaml file and combines inputs from prconfig.xml to create the final cassandra.yaml which gets bootstrapped.
But as an Ops person, I need to know how I can configure this without using the UI in order to create a configuration deployment process that is repeatable.
How can I achieve activation and allocation of the D-Nodes via prconfig.xml (and/or other config files) alone? If for whatever reason this is not possible, is there an alternative way I can create a repeatable process?
