ING Vysya Bank Ltd
Last activity: 12 Dec 2017 18:14 EST
DNode Configuration
Hi Team,
We are working on setting up the decision application. We need to configure DNode for the Decision application. We have a PRPC server through which we wanted to connect to DNode which is hosted on another server.
To connect to external cassandra cluster i have added valid host names and supplied the valid cassandra DB credentials.After submitting the form still i see the Add Node button being disabled. Please find the attached
Can someone please help if we are missing something here.
Also we have a server which we wanted to run for the ADM services. Can you help how to configure my prpc server to communicate to the ADM server.
We are working on Pega Version 7.2.2
Regards
Manju
i can see that the attached logic to dictate whether the Add Node button is enabled or not.
Societe Generale
venkata ratna raviteja bezawada Priyadarshini Anandan Srividya Chinni
Is the other node which is hosted on another server is part of the same PRPC Cluster (connect to the same pegarules/pegadata schema) as your current one?
ING Vysya Bank Ltd
No its not part of the same cluster.
There are 4 different types of DNodes - DDS (Cassandra), ADM, Data Flow and Real Time Grid(VBD). With the exception of DDS which can connect to an external cassandra cluster as well, all the other types of DNodes requires a PRPC node part of the same cluster. If you have a multi node setup then you can identify what type of DNode each PRPC node is and add them accordingly. If it is a single node setup then you can configure all of the Dnodes types to be running in same node but this is not a ideal setup.
If this is is being done for a real customer then I would recommend you to reach out to your Account Executive and work with GCS to understand and configure accrodingly.
ING Vysya Bank Ltd
Yes we need to configure DDS which is an external cassandra. I don't see the external node appearing in the add node. Can you please help us to understand the configuration at the prpc node to see the external cassandra node.
Please go thru the link that dacoi has replied in the below comment. It explains on how to connect to external cassandra cluster.
Wellsfargo
anyyy help would be appreciated
Have you looked at information in the article about integrating with external Cassandra?
Do you have a screenshot under the Decision Data Store page? Like mentioned in the link above, you can start by clicking Edit Settings from the Decision Date Store and configure to connect to external Cassandra.
