Bank Of America
Last activity: 31 Dec 2015 4:54 EST
Is Pega 7 supports incoming email decryption using Private Key ?
Is Pega 7 supports incoming email decryption using Private Key i.e Keystore ?
Yes, it is possible. However, I'm not able to point you to the right document at this point. Give me some time to write it up for you.
I'm a little held up with other things. Please go through the following rules and see if you can make anything out of them.
Activities
Data-Admin-Security-Keystore.pyGetEmailCertificates
Data-Admin-Security-Keystore.pyGetEmailCertificateDefault
Decision table
Data-Admin-Security-Keystore.pyEmailCertificateMap
You need to customize this decision table to provide a mapping between email address and keystore instance and keystore alias for decryption.
Bank Of America
Hi Praneeth,
This activity and decision table comes in picture when you are sending encrypted mail from pega.
I have implemented same to send encrypted mail from pega using keystore of receiver email id.
Do you mean, if I give mapping of email id and keystore in pyEmailCertificateMap decision table for email id used for inbound mail in pega will decrypt the incoming mail automatically.
Please update.
Thanks & Regards,
Nitin Desai
Yes Nitin, the same rules are used on the inbound side as well. Could you try and let me know the outcome.
Bank Of America
Hi Praneeth,
As still I am waiting for my IMAP connection to test provided solution. Will update you with result.
Bank Of America
Hi Praneeth,
I tried the solution you provided but getting below error message when listener try to read email
2015-12-31 14:34:36,482 [fault (self-tuning)'] [ STANDARD] [ ] [ ] ( services.email.EmailListener) INFO EMAIL.NDEmailListener.Listener|from(sanket.mohile@atos.net) Admin@ND - Messages are not processed.
javax.mail.MessagingException: Error occurred while attempting to decrypt email;
nested exception is:
java.lang.Exception: Unrecognized message format
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.decryptMessage(EmailListener.java:2586)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.handleRequest(EmailListener.java:3164)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.emailProcess(EmailListener.java:2849)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.oneIteration(EmailListener.java:2301)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.run_(EmailListener.java:2206)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:448)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:212)
Hi Praneeth,
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:166)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor123.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:238)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at sun.reflect.GeneratedMethodAccessor122.invoke(Unknown Source)
at com.bea.core.repackaged.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at com.bea.core.repackaged.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at com.bea.core.repackaged.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at com.bea.core.repackaged.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at com.bea.core.repackaged.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at com.bea.core.repackaged.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at com.oracle.pitchfork.spi.MethodInvocationVisitorImpl.visit(MethodInvocationVisitorImpl.java:34)
at weblogic.ejb.container.injection.EnvironmentInterceptorCallbackImpl.callback(EnvironmentInterceptorCallbackImpl.java:54)
at com.oracle.pitchfork.spi.EnvironmentInterceptor.invoke(EnvironmentInterceptor.java:42)
at com.bea.core.repackaged.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:89)
at com.bea.core.repackaged.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy49.invokeEngine(Unknown Source)
at com.pega.pegarules.internal.etier.ejb.EngineBMT_h449u3_ELOImpl.__WL_invoke(Unknown Source)
at weblogic.ejb.container.internal.SessionLocalMethodInvoker.invoke(SessionLocalMethodInvoker.java:39)
at com.pega.pegarules.internal.etier.ejb.EngineBMT_h449u3_ELOImpl.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.onMessage(PRAsync.java:112)
at sun.reflect.GeneratedMethodAccessor121.invoke(Unknown Source)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
at com.pega.pegarules.internal.etier.mdb.PRAsyncBoot.onMessage(PRAsyncBoot.java:91)
at sun.reflect.GeneratedMethodAccessor120.invoke(Unknown Source)
at $Proxy77.onMessage(Unknown Source)
at weblogic.ejb.container.internal.MDListener.execute(MDListener.java:583)
at weblogic.ejb.container.internal.MDListener.run(MDListener.java:902)
at weblogic.work.SelfTuningWorkManagerImpl$WorkAdapterImpl.run(SelfTuningWorkManagerImpl.java:545)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: java.lang.Exception: Unrecognized message format
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.decryptMessage(EmailListener.java:2565)
... 69 more
2015-12-31 14:34:36,482 [fault (self-tuning)'] [ STANDARD] [ ] [ ] ( services.email.EmailListener) DEBUG EMAIL.NDEmailListener.Listener|from(sanket.mohile@atos.net) Admin@ND - Attempting to mark the message as 'seen'
Thanks & Regards,
Nitin Desai
