Parent Ruleset
How do you change this .pylabel name to a property in your application(Mine is .customername)
so that it shows the customer name there instead of the label name.
"Recents" will show all recently opened items. It will display ".pyLabel" values.
Why do you want to change this .pylabel name to another property name?
Can you check Data Transform "pyAddRecentListItem"? This DT is called to set properties like pyLabel, pyDescription, pyIsDirty etc while loading recents Data page.
You may have the options to change the .pylabel, description etc. in this Data Transform.
