Reply
IT
Last activity: 21 Mar 2016 6:11 EDT
Overriding Locking Strategy for children cases
I have a scenario where a Case A can have 3 children: case B, C and D.
Case A locking strategy is defined as Default so every covered case will inherit the same locking stragegy. My requirement is to have Case B configured with Optimistic locking while still being covered by Case A, while Case C and D should retain Default locking strategy. As far as i know this is not possible (at least up to pega 7.1.7) which is the version we are running.
I found a possible workaround which, i fear, is not exactly pega compliant but it's not that bad either.
Here it goes:
Let's suppose we have Case A instanced with all the 3 child Cases. We have something like that:
- CASE A
|_CASE B
|_CASE C
|_CASE D
When an operator tries to open a Case the acquireWorkObject API is called, in the contest of the execution the locking strategy is determined by pzGetLockingMode activity:
Said activity basically consists of a java step that checks for the locking strategy of the topmost case (A in our example) by reading pyDefault rule (of type Rule-Obj-CaseType)
Knowing that pzGetLockingMode has pyWorkPage as a Primary page i wondered if i could save a circumstanced instance of pyDefault to be read only when Case B is being locked
Here it goes:
- CASE A
|_CASE B
|_CASE C
|_CASE D
Having saved a circumstanced rule i tried to modify the logging strategy but the advanced tab of the circumstanced rule wasn't editable.
Still, by checking the xml structure of the rule (Actions->View XML), the locking strategy is presend with "Default" value
<pyLockingMode>Default</pyLockingMode>
So what i did is:
1- delete the circumstance rule
2- Edit pyDefault rule (in Case A) setting locking strategy to Optimistic
3- Save a new circumstanced rule as defined above. Advanced tab is still not editable but pyLockingMode is set to Optimistic
4- Revert pyDefault rule (in Case A) back to Default locking strategy
5- Circumstanced rule is still set to Optimistic locking
Now i can instantiate a case structure with the following locking strategies
- CASE A (Default)
|_CASE B (Optimistic)
|_CASE C (Default)
|_CASE D (Default)
I've run a few test and it seems to be stable enough, but still i've no idea of possible side effects.
Have you already faced a similar problem? Did you find another solution?
Roberto
