Morgan Stanley
Last activity: 5 Jan 2018 12:48 EST
Does locking of parent case lock child cases
1. I have a parent case P which has default locking configured and has a child case C1. If i lock P, will it also lock C1 in default locking
2. If i lock C1, will it lock P as well.
Hi Hari,
1. I have a parent case P which has default locking configured and has a child case C1. If i lock P, will it also lock C1 in default locking? -> In this case the child object will also be locked
2. If i lock C1, will it lock P as well? -> It depends on the setting you choose in the child case whether to lock the parent case or not which can be seen in Case > Advanced Tab > Do not lock the parent case when the child case is being performed checkbox.
Hope its clear for you.
Regards
Mahesh
Akhil Teja Kolluru
EPAM Systems, Inc.
ES
Adding to my colleague,
OOTB you can lock a Parent case when a child case is performed. In fact, this is the default behaviour.
Look at the Case Designer "Locking Strategy" for a subcase. By default, a child case locks its parent.
You need to check the "Do not lock Parent case" checkbox to enable subcases to NOT lock their parent, hence subcases may be performed independently.
Morgan Stanley
Thanks friends.
So, in a child case with parent as default, we have two options 1) optimistic 2) do not lock parent
Are these options not same?
Can you please go to this link. It will help you differentiate between the two.
https://docs-previous.pega.com/locking-cases
Rachit
Optimistic locking is the different locking mechanism which allows multiple operators to access the work object at a time without holding lock. The first operator who commits his work will get the lock and the second operator will be intimated with the alert stating that work object has been modified.
Whereas the Do not lock parent.. can be used in the default locking mechanism to restrict child case to be locked/not locked.
Publicis Sapient
Vandhan Singh rajaputra Mauricio Bolanos Canjura Rajendra Prasad Ega
Similar query has been answered here
https://collaborate.pega.com/question/parent-case-lock-vs-child-case-working
For more information on case locking you can go through this link .
Arun
