Out Parameters from Data Transform to HTML are blank
Greetings. Hope you are all doing well! I am on Pega 8.7.1, i am trying to use ShowHelpStream to populate the guidance for Flow actions, i am calling a Data Transform from the HTML.
I am able to set the parameters within the Data Transform and i can see these but as soon as the DT ends and control reaches the Stream rule, i cannot see the parameters.
I have seen an article from 6 years https://support.pega.com/question/data-transform-not-setting-output-parameters which says this will be addressed in future releases,
Can someone please confirm if the issue i am seeing is still there?
***Edited by Moderator Marije to add Capability tags**
