TATA Consultancy Services
Posted: Sep 28, 2017
Last activity: Oct 13, 2017
Last activity: 13 Oct 2017 6:15 EDT
OpenSpan Integration to Mainframe screens(PC to Host passport application by Rocket)
I am looking for some help ,how to access Mainframe screens (IBM tool called PC to Host passport application) using openSpan(7.1). Can someone help me with documents where it explains.
Thank you.
Start here: http://help.openspan.com/71/Text_Adapters/Interrogating_Attachmate_Rumba_and_WRQ_Applications.htm
Follow the links to see more about it. The main piece of information that you need to find out is if the emulator uses the hllapi or ehllapi dlls. This is the API that Pega Robotics uses to communicate with the mainframe. If it does not have this dll then the simple answer is that Pega Robotics won't be able to work with it. Some emulators require special configuration to have the mainframe utilize this dll so following up with the application team that manages this will also help you in determining if you can automate it.
