Accenture
TR
Last activity: 2 Jul 2018 10:02 EDT
Opening an Existing Case Work Item from Flow Activity - pyCommitError DB Save using an insert failed
We need to open an existing case from within another case using an activity but we are getting database insert error. It seems to be doing a Commit Action when we try to open the case.
Is there a way to NOT make a commit action or any possible solutions to this problem?
Thnx in advance. Please find the detailed problem description below:
Pega platform: 7.1.7
Problem: Opening an existing non resolved case with a known case ID in Perform mode. Main Case which will open the existing one is called UW, and case to be opened is ELM
- UW case calls the flow “ElmForUW” as sub process
- ElmForUW flow checks for existing elmas inquiry and if exists, gets the case ID and calls an activity to open existing work with case ID (pyID)
- In open existing case activity, We use Obj-Open with Class of the case: XX-FW-ELM-Work-ELMInqCase, also use stepPage directly with pyWorkPage which is also of the same class.
- When I run the flow ElmForUW, i get the following error: .pyCommitError: ** Database save using an insert failed
When Tracer is checked, we see that after finding related existing case, system is trying to do a commit action and gets an error, there are no previous errors.
Tracer errors are as follows:
| 1332 | TABTHREAD4 | 1027 | 14 | Activity End | 7.4380 | @baseclass doUIAction | Pega-UIEngine 07-10-15 | |||||
| 1331 | TABTHREAD4 | 1027 | 14 | java | 21 | FAIL | Step End | 7.4120 | @baseclass doUIAction | Pega-UIEngine 07-10-15 | ||
| 1330 | TABTHREAD4 | 1027 | 16 | Activity End | 7.4110 | Work- NewFromFlow | Pega-ProcessEngine 07-10-11 | |||||
| 1329 | TABTHREAD4 | 1027 | 16 | Call New | 5 | FAIL | Step End | 7.4100 | Work- NewFromFlow | Pega-ProcessEngine 07-10-11 | ||
| 1328 | TABTHREAD4 | 1027 | 17 | Activity End | 7.4100 | Work- New | Pega-ProCom 07-10-15 | |||||
| 1327 | TABTHREAD4 | 1027 | 17 | Call Add | pyWorkPage | 12 | FAIL | Step End | 7.0020 | Work- New | Pega-ProCom 07-10-15 | |
| 1326 | TABTHREAD4 | 1027 | 26 | pyWorkPage | Activity End | 6.9860 | Work-Cover- Add | Pega-ProcessEngine 07-10-15 | ||||
| 1325 | TABTHREAD4 | 1027 | 26 | Call WorkCommit | pyWorkPage | 5 | FAIL | Step End | 4.5330 | Work-Cover- Add | Pega-ProcessEngine 07-10-15 | |
| 1324 | TABTHREAD4 | 1027 | 48 | pyWorkPage | Activity End | 4.5010 | Work- WorkCommit | Pega-ProcessEngine 07-10-01 | ||||
| 1323 | TABTHREAD4 | 1027 | 48 | Call HandleCommitFailure | pyWorkPage | 7 | GOOD | Step End | 2.7800 | Work- WorkCommit | Pega-ProcessEngine 07-10-01 | |
| 1322 | TABTHREAD4 | 1027 | 53 | pyWorkPage | Activity End | 2.7480 | Work- HandleCommitFailure | Pega-ProCom 07-10-01 | ||||
| 1321 | TABTHREAD4 | 1027 | 53 | Activity-End | pyWorkPage | 5 | GOOD | Step End | 0.0160 | Work- HandleCommitFailure | Pega-ProCom 07-10-01 | |
| 1320 | TABTHREAD4 | 1027 | 53 | Activity-End | pyWorkPage | 5 | Step Begin | Work- HandleCommitFailure | Pega-ProCom 07-10-01 | |||
| 1319 | TABTHREAD4 | 1027 | 53 | Call DisplayHarness | pyWorkPage | 4 | GOOD | Step End | 2.5060 | Work- HandleCommitFailure | Pega-ProCom 07-10-01 | |
| 1318 | TABTHREAD4 | 1027 | 54 | pyWorkPage | Activity End | 2.4740 | Work- DisplayHarness | Pega-ProcessEngine 07-10-01 | ||||
| 1317 | TABTHREAD4 | 1027 | 54 | Branch Show-Harness | pyWorkPage | 2 | GOOD | Step End | 2.3770 | Work- DisplayHarness | Pega-ProcessEngine 07-10-01 | |
| 1316 | TABTHREAD4 | 1027 | 55 | pyWorkPage | Activity End | 2.3120 | @baseclass Show-Harness | Pega-UIEngine 07-10-15 | ||||
| 1315 | TABTHREAD4 | 1027 | 55 | java | pyWorkPage | 6 | GOOD | Step End | 2.0190 | @baseclass Show-Harness | Pega-UIEngine 07-10-15 | |
| 1314 | TABTHREAD4 | 1027 | 55 | When Rule Evaluation | pyWorkPage | False | When End | 0.0160 | @baseclass recordEvent | Pega-UIEngine 07-10-01 | ||
| 1313 | TABTHREAD4 | 1027 | 55 | When Rule Evaluation | pyWorkPage | When Begin | @baseclass recordEvent | Pega-UIEngine 07-10-01 | ||||
| 1312 | TABTHREAD4 | 1027 | 55 | When Rule Evaluation | pxThread | True | When End | 0.0020 | Code-Pega-Thread IsUserThread | Pega-WB 07-10-01 | ||
| 1311 | TABTHREAD4 | 1027 | 55 | When Rule Evaluation | pxThread | When Begin | Code-Pega-Thread IsUserThread |
Pega-WB 07-10-01
| Activity Name | COMMITWITHERRORHANDLING |
| Activity Number | 49 |
| Parameter Page Name | =unnamed= |
| Primary Page Class | XX-FW-ELM-Work-ELMInqCase |
| Primary Page Name | pyWorkPage |
| Step Method | Commit |
| Step Number | 4 |
| Step Status | FAIL |
| Step Status Info |
Database save using an insert failed |
HI There,
Please check if the lock was held while performing obj-open.
Ujjwal
