OOTB API response to GET /docs contains errors
Version: Pega 8.6.5
API: /docs
The response to the API Request contains errors which makes that the API response is not accepted by external application.
Request URL: {baseURL}/prweb/api/v1/docs?category=Application
Errors in response:
- line 129 / 130 --> values for enum (in the get for the tag ["attachments"] ) should be true or false (without " "), now they have " " around them which causes an error message
- line 2578 --> "$ref": "#/definitions/Header" should be "$ref": "#/definitions/Header" (with the # and an extra S behind definition)
Please fix this response as it hinders the correct working of this OOTB API
@MennoR80 I did a search on our systems and am unable to find any known issues relating to the above.
The documentation does not provide any further details on expected format.
Note: There is no point requesting a software 'fix' on this PSC forum. In order to get this investigated and logged with our Engineering team please log this as a support 'issue' ticket on the MSP so that our Engineering teams can get this looked at and tracked with a support ID.
Please familiarize yourself with the Getting support at Pega processes.
