Online help system version comparison
Here is a common concern when I comparing between different version of Pega Help System.
For instance, 7.1.9 does have following statement while 7.2.2 doesn't.
To disable page passivation, add the following element to the prconfig.xml file:
<env "initialization/persistrequestor/usepagelevelpassivation" value="false" />
Suppose if I am working on 7.2.2, will strictly follow up the same version of help, or even previous version of contents are available too?
//Thanks,
Hi Billy,
As part of US-99873(For internal purpose) for ML10, the setting "initialization/persistrequestor/usepagelevelpassivation" is being removed. Functionally, passivation will behave as though this is true, which indicates that we are using the "new" passivation model.
If the setting has been configured as false, an infoForced message will be output from PRSessionProviderImpl at initialization.
"The setting initialization/persistrequestor/usepagelevelpassivation has been configured as false, but this setting has been deprecated and will be ignored. Page-level passivation will be used."
And to answer your question
Ans :Help Documents are created for each pega release and you can follow for that particular version .
Arun
