Rabobank
Last activity: 31 May 2019 10:49 EDT
Not able to Validate Multiple XSD's (XSD embedded with another XSD) in Parse XML
Hope you are doing well!!!
We have a requirement where in we have to validate the data in a single XML with Multiple XSD's (Meaning a main XSD has another XSD embedded which is called by using Import).
I expected this to work when i placed both the XSD's on a common server path and refer the same in the schema URL field(in XML Tab) in Parse XML but am getting following error message everytime when i tried that,
** FAIL : Unable to apply Rule-Parse-XML instance. Failed to parse XML. Error: Premature end of file.
I tried by first creating a Parse XML using these XSD's using Meta data wizard and then use the same for validation but am, unfortunately, getting the same error.
Am trying to figure out the other possibilities before going ahead and raise an SR.
I would appreciate if you can help me in figure out the issue!!!
Syed
