Validating Request XML(SOAP) against XSD at client side
Is there any way to validate the request xml against the XSD at clinet side i.e. before making a call to the service?
I know that there is a RUF to achevie this. But looking for the options if any from Connect-SOAP or XML stream rule to configure?
I'm aware this post is relatively old, but in case you're still wondering, or if someone else comes across this in the future, you can do this using the Rule-Utility-Function validateAgainstXSD and a little custom processing. See the following SA for details: https://community.pega.com/support-articles/pega-does-not-validate-outgoing-soap-requests-against-xsd
There's no option to do this directly from the Connect rule or XML stream rule.
