Not able to see the images in PDF after converstion from html stream to pdf using OOTB HtmltoPDF
We have a requirement like need to display images which are added by the end user in pdf file .this pdf file will be available as dowloaded kind of thing.
we are able genarate pdf and all the data is comming properly the issue is user attaching images to the work object or case not populated in the final generated pdf document.
in html view means in browser we are able to see images but incase of pdf file we are unable to see the images.
steps we followed
1) created activity this will populate the data to be included in pdf
2) create a html rule(which is having all clipboard data and images data) we are just refering using <pega> tags
3) calling ootb HTMLTOPDF which will converting html stream to pdf
Please share your ideas/Suggestions.
Pramod Kotha
***Updated by Moderator: Marissa. Removed user added #helpme, Ask the Expert, and FAQ group tags. Apologies for confusion, shouldn't have been an end-user option; updated categories***
