Not able to connect pgAdmin4 after installing pega 8.6
Installed Pega 8.6 personal edition and then trying to launch pgadmin4 and getting error " the application server could not be contacted" fatal error. tried to run as a administrator but no luck.
please help me on this. couple of times re-installed but no luck.
***Edited by Moderator Marije to change type from Discussion to Product, added Product details and Capability tags****
@RameshN3 this issue appears to be a PostGres issue, rather than Pega. Did you check with the DB vendor?
Perhaps you could check the following:
https://stackoverflow.com/questions/43211296/pgadmin4-postgresql-application-server-could-not-be-contacted
Other suggestions:
https://postgresrocks.enterprisedb.com/t5/EDB-Postgres/pgAdmin-v4-The-application-server-could-not-be-contacted/td-p/2006/
https://www.pgadmin.org/docs/pgadmin4/development/connect_error.html
If pgAdmin displays this message, there are two possible reasons for this: the database server isn't running - simply start it. the server isn't configured to accept TCP/IP requests on the address shown.
In case it is attempting to use the sessions from the prior version:
If running the pgadmin 4 by Administrator is not helpful in your case then try clearing out the "C:\Users\{YourUser}\AppData\Roaming\pgAdmin" folder.
Alternatively, to resolve PgAdmin Fatal Error:
https://postgrespro.ru/list/thread-id/2507859
It would be best if you check with the DB vendor and network team.
