Newly added property is not appearing when open the work object.
Hi Team,
I have requirement to add a new property to the work table and it should be available for reports, so a new property was created in work class and it is manually added to the work table via alter SQL querty. For the existing resolved work objects the data patch was done through update SQL, since resolved objects cannot be updated from PEGA with out re-opening.
Report are working as expected based on the newly added property but when a existing case is opened (review / re-open) the property was not appearing on pyWorkPage, however it is working as expected for newly created work objects.
Expecting a prompt response. Thank you.
