Capgemini
FR
Last activity: 15 Feb 2017 14:40 EST
Need Hotfix mentioned in SA-32268 but for Pega 7.2.1
Do you know if this hotfix mentioned on https://community.pega.com/support/support-articles/dwa-pzsus-param-not-properly-urlencoded-http-400-errors is also available for 7.2.1 because we reproduce the same issue? thanks
Regards
***Updated by moderator: Lochan to edit title; add SR details***
Capgemini
FR
Hotfix has been delivering by Pega support and we've installed in our Development and Test environment and it's working fine.
I just don't understand why this hotfix was not available before for this version...
The bug raised for this hotfix is targeted to be fixed in 7.3 release. Please raise an SR to get the same for 7.2.1.
Hope this answers your query.
Best Regards,
Mounika
I do not see a hot fix for Pega 7.2.1. There is a hot fix available for 7.2.2 if you will be updating. If you are not able to update to 7.2.2, then you can open an SR to see if the hot fix can be ported to 7.2.1.
Pega 7.1.9 - HFix-31198
Pega 7.2.2 - HFix-31834
Hello!
Do let us know us know the SR number if you create one with Pega Support. We will track it through this post!
Lochan | Community Moderator | Pegasystems Inc.
Capgemini
FR
Thanks for your replies. I will add the SR number when created.
Regards
Capgemini
FR
Here's the SR number: SR-B30923
Regards
Updated: 9 Feb 2017 6:25 EST
Thanks Alex!
I have tagged that with your original post above!
Capgemini
FR
