Infosys Limited
Last activity: 15 Sep 2023 9:38 EDT
Navigate to next screens in layout groups using buttons
I have a requirement to navigate the screens using buttons. The section is using the layout group currently. In the earlier versions the tab layout has been used and for the navigation button the action set used is "On Click -> Run Data transform (Tabchange). So, for our current requirement how can we implement the action set to navigate to next screen?
@HemanthBorra To implement navigation buttons in a layout group, you can follow these steps:
Now, when users click the button, the specified data transform will be executed, and the navigation will occur based on the logic defined in the data transform.
This answer came from a Pega gen-AI assistant using the below references. As a Support Center moderator, I reviewed the answer and references for accuracy:
Adding action sets to a layout
Managing visibility of a group layout tab
Configuring action buttons for a flow action
