Virtusa
Posted: September 20, 2016
Last activity: September 22, 2016
Last activity: 22 Sep 2016 11:02 EDT
Multiple Values of same paramters in query String
Detailed Description
Requirement : Call the Connect-rest (GET) method using the query string parameters
Service URL : http://azdev-esb1/api/v.0.6.0/vela/daily_note_submissions?consumer_ids=88622&consumer_ids=4347&datefrom=2016-09-14&dateto=2016-09-15
Issue : In the GET method of connect-rest we only have an option to pass query string parameters , we are not able to pass multiple consumer ids in the request.
Steps to Reproduce
1. Create a connect-service (GET) which takes multiple values in same parameters of the query string (kind of array)
2. Run the metadata and connector wizard with the service URL
Show More
Steps to Reproduce
3. try to call the service by passing the required values .
Error Message
No
Attempted Solutions
We tried to manually format the query string parameter by appending "&consumer_ids=" and pass to the service URL .
But Pega internally does the URL encoding and converts the special chars like "&" and "=" due to which the service fails
2016-09-20 10:45:29,278 [tp-nio-8443-exec-124] [ STANDARD] [ ] [ SLCM:01.01.01] (ector.Rule_Connect_REST.Action) DEBUG aacharya - URL constructed is: http://azdev-esb1/api/v.0.6.0/vela/daily_note_submissions?consumer_ids=88622%26consumer_ids%3D4347&datefrom=2016-09-14&dateto=2016-09-14
***Updated by moderator: Lochan to add Category***
Show Less
