Multi select control does not work in Pega Offline Access Mode
Hello All,
We are trying to achieve Offline Capability for our case type. Below is the scenario:
User should be able to create & work on existing cases for a case type. For this we have configured the Access Group and case type to support offline processing.
At the very first step of the case we have a screen-flow, and the 1st screen contains a multi-select list sourced with a data page (List,Read Only, Thread & source-RD).
The values are populated on screen load, and we are able to add values into it.
Post this, once we submit the screen and move on to the 2nd screen (of screen-flow) and again move back to the first screen (by pressing the back button), the app gets hanged.
We tried some trial and error with all the fields from the 1st screen and thus came to know it is the multi-select control which is causing the issue.
Notes: We are using app express downloaded from play store and logging in by entering the URL of our server.
Any leads would be appreciated. Thanks in advance.
