Mule Pega connector Put operation on cases resource not working
Hi Team,
I am working on a mule POC to use Mule Pega connector. I am using following URL as reference
I am able to make most of the operations except PUT on cases resource.
I am facing issue with PUT operation in the portal it says to send ETag as If-match header which is received in header during get operation or create operation on a case. I tried the same. But, always getting error message that
"pxObjClass": "Pega-API-CaseManagement-Case",
"errors": [
"ID": "Pega_API_021",
"message": "Unauthorized access: If-Match does not match ETag",
"pxObjClass": "Pega-API-Error"
header being sent is
If-Match=20170519T063422.162 GMT
Authorization= <something>
Content-Type=application/json
Cache-Control=cache
where if-Match is the value of the etag which we get while doing get for same case.
Could someone please help me on this.
Hi Team,
"errors": [
Cache-Control=cache
