Modal dialog not launching from repeat grid using embedded page list
I have three repeat grids, each in different sections. They all reference the same section in a section include for one of the columns. The included section has an image with an on click event to launch a modal dialog. This works fine for 2 out of the 3 repeat grids. After testing I have found this is because the one that doesn't work is using an embedded page as the List/Group. I have also tried using both onClick events 'Open local action' and 'Launch: Local action' with the same results.
The only work around for this issue I have found is to copy the page list to a dummy top level clipboard page. Does anyone know of a more elegant solution?
Also, we're on Pega v7.1.6. Is this bug fixed in later versions?
***Updated by Moderator: Marissa - to add category***
Could you provide screen shots showing the good versus bad behavior? Along with repeat configuration deltas
