Transport for NSW
Last activity: 8 May 2020 15:51 EDT
Missing Pega 7 Platform shipped schema objects displayed in 722-8.41 upgrade
We've upgraded from Pega 7.22 environment to Pega 8.41 successfully and while running post upgrade steps, we observed the below in 'Upgrade Application Schema' landing page.
As part of post upgrade steps, we upgraded data tables, work tables and history tables but didn't understand why 'Pega7 related schema objects info' is being shown though it is Pega 8 upgrade.
Before this, we've also upgraded different environment (with same code base) from Pega 7.22 to Pega 8.32 and we didn't see this issue on Pega 8.32. Is this a known issue on Pega 8.41?
When we ran the upgrade scripts, we went with the defaults settings of setupdatabase.properties which means the schema changes would have been applied successfully.
# BYPASS SCHEMA GENERATION? # Schema generation will be skipped if this property is set to true # Note: Leave this property blank to generate the schema bypass.pega.schema=
# BYPASS UDF GENERATION? # UDF generation will be skipped if this property is set to true # Note: Leave this property blank to generate the UDFs bypass.udf.generation=
Any idea why we're seeing this pega 7 related objects missing on Pega 8.41? Any quick help is greatly appreciated as we would like to know if we're missing anything before upgrading other environments.
Thanks.
***Edited by Moderator: Pallavi to change type from General to Product, add platform version***
