Ucare
Posted: April 18, 2018
Last activity: April 19, 2018
Last activity: 19 Apr 2018 10:55 EDT
Hello, We updated our application from pega 7.1.7 to pega 7.3.1 and after update, the logs are not getting generated. Did anyone get similar issue and how did you guys resolve it ?
Hi Kavitha,
Post Pega 7.3, the prlogging.xml file has been replaced with the prlog4j2.xml file. So you might have to configure this to your desired directory.
Also, check the following link as well if it helps you:
https://collaborate.pega.com/question/logging-configuration-post-update-73-718
Hi Ajay,
I am not able to locate prlog4j2.xml at all in our app server. Not sure whether we need to import some log jar file and then try to replace the prlogging.xml with prlog4j2.xml .
