Log size increase/Decrease or method change in version upgrade to PRPC V7.3
Dears,
We are upgrading from PEGA V7.1.7 to V7.3.
Will this upgrade have any effect on the daily log sizes, any features introduced to compress logs etc.
Is there any changes in the default prlogging.xml and rolling mechanism. Any enhancement of remote logging(logfactor5).
Thanks in advance.
In prpc 7.3 prlogging.xml file has been replaced with the prlog4j2 file. This file contains the configuration settings for logging.
you can go through the below links which will give you more detailed information:
https://pdn.pega.com/pega-platform-logging-log4j-2-logging-service/pega-platform-logging-log4j-2-logging-service
https://docs-previous.pega.com/system-administration/84/customizing-logs
Thank you
