Accenture
Last activity: 28 Jul 2016 6:29 EDT
Log Rotation with DailySizeRollingFileAppenderPega
I am working on rotating my log files from within Pega based on Time and Size with the DailySizeRollingFileAppender in Pega 7.1.9. The application is running on JBoss EAP 6.4.4 on RHEL 6.
The time based portion of the appender seems to be working fine, but I am trying to also rotate based on the 'MaxFileSize' parameter. I lowered the value to 250KB for testing, but the log file is still being written to after the log size is met. Am I misinterpreting how the appender should work? or is something wrong with the syntax below? the $pega.log.location is a variable that I am passing via JAVA_OPTIONS
<appender name="test_file" class="com.pega.pegarules.priv.util.DailySizeRollingFileAppenderPega">
<param name="FileNamePattern" value="'${pega.log.location}/test_file-'yyyy-MM-dd-a'.log'"/>
<param name="MaxFileSize" value="50MB" />
<layout class="com.pega.apache.log4j.PatternLayout">
<param name="ConversionPattern" value="%d [%t] %-5p %c- %m%n"/>
</layout>
</appender>
Jeff
