How to enable log rotation in Tomcat 8.5
We need to enable log file rolling of tomcat logs. Does anyone point me how to do the same?
Manju.
Manju.
Do you mean the pegaRULES logs? If yes, provide the Pega version
No, its tomcat-stdout logs in Tomcat/logs folder
Hi Manju,
You can have a look into this discussion answer regarding your query which might help you to proceed further. The referred discussion explained with the tomcat 6.0 logging documentation reference, as you are using tomcat 8.5 sharing the corresponding logging documentation over here.
Hope this might help you to proceed further.
Regards
Mahesh
The following steps describe configuring log4j to output Tomcat's internal logging.
With the help of DailyRollingFileAppender you can roll the logs daily .
For more information go through below article.
https://tomcat.apache.org/tomcat-7.0-doc/logging.html#Using_Log4j
Arun
Hi Arun,
We tried implementing the changes, Tomcat is not starting even catalina file itself is not getting creating (attaching logs). Our Tomcat version is "8.5.23"
Even i tried following the steps in the link that you attached for the reference, still no luck !!
Please assist.
Thanks & Regards,
Narhar Dev Sharma
