Last activity: 27 Nov 2020 9:46 EST
Lock Gone Exception on Tickets created from Interaction portal
For my telecommunication Application,we are creating ticket from the InteractionPortal.
Ticket is having an SLA defined, on SLA - Passed Deadlin, there is an activity being Invoked.
In the Activity I could see there is obj-Open-by Handle with Lock(enabled) and release on commit(enabled).
In those activity I do have obj-save in later sub activities which are invoked.
In the logs I could see lock gone exception on T-123 with below stack trace:
ExecuteSLA.Assign_.Action) ERROR - obj-save failed.
com.pega.pegarules.pub.database.LockGoneException: Save, Delete or Commit has failed because lock "TELENET-ADT-WORK T-123" is not held
at com.pega.pegarules.data.internal.access.Saver.checkRequiredLock(Saver.java:1243) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.access.Saver.saveDeferred(Saver.java:439) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.access.DatabaseImpl.saveDeferred(DatabaseImpl.java:2756) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.access.DatabaseImpl.saveDeferred(DatabaseImpl.java:2739) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.access.DatabaseImpl.saveDeferred(DatabaseImpl.java:2732) ~[prprivate-data.jar:?]
at com.pegarules.generated.activity.ra_action_executesla_464350f6cf89e0b6dd36c2aed60a7659.step23_circum0(ra_action_executesla_464350f6cf89e0b6dd36c2aed60a7659.java:2536) ~[?:?]
I could see on execute SLA obj-save lock is going , If there be any Issue if I use obj-open by handle with lock(disabled) and release on commit(disabled) , I am not able to understand the root cause where lock is going. Please provide any solution to proceed further.
