Lock "Already Owned Lock"
I have implemented a test using the Obj-And-Refresh Method.
As you can see in attachment, the step of Obj-And-Refresh Method (step 5), the column EVENT TYPE indicates “Already Owned Lock”.
So in the Jump of the step 5, is there a way to check whether we are in case “Already Owned Lock”, through a @base property to check or anything else ?
