Load Balancer for Production Pega Based applications
Currently customer have pega based applications in production on 7.1.7 on hosted on two nodes running on Windows Platform with Apache Tomcat server. Now they are planning to imlement Pega HA availability and Load Balancer. In this context customer need expertise and advice to proceed with HA features available and LB.
Need help on the below queries.
1. Applications were developed on Pega 6.2 initially and later platform is upgraded to Pega 7.1.7. However still the applications are working fine as per functionality.
Is there any limitation if HA features to be implemented as per Pega 7.1.7 and there any challenges involved. Please specify if this is a blocker to implement High Availability Features in Production.
2. Customers have two nodes and if the agents are enabled on both the nodes will there any contention issues. Also specify if Load Balancer is implemented.
3. If user is working on one of the node and other node is down , if the agent enabled on working node will the user request be catered via UI. Please specify if there is any impact if Load Balancer is implemented from this context.
**Updated by Moderator: Vidyaranjan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option***
