Capgemini
Last activity: 28 Feb 2017 13:03 EST
In line dynamic layout is not working as expected
At run time its showing as stacked instead of inline
PFA screenshot
Updated: 28 Feb 2017 9:59 EST
Techmahindra
Hi Pandj,
Please see the document I have attached where I have tested it when making changes to the presentation tab.
Ensure you modify it to both the inner layouts for it to work.
Shanthini Charles
I couldn't see the behaviour you mentioned here:
1)Please verify if the preview is also showing the same way ?
2)Try to configure the same in some other sample section and check the behaviour
3)Check if by anychance self clear, clearfloatedlayouts checkbox is enabled on the dynamic layout properties or not ?
Capgemini
Can you try with v7.2.1?
Yes the above screenshots are from 7.2.1 prpc version.
Hi Pandj,
Even I tried in 7.2.1, I am getting same format.
Kindly verify your configurations. Please find the attached images of configuration at my end.
Gurpreet Kaur
Capgemini
Can someone pls check in IE in PRPC 7.2.1?
as its working fine in mozilla/chrome.
Techmahindra
Hi Pandj,
Yes I could reproduce the same only on Internet explorer. Also I see some known issues on Internet explorer when displaying inline block.
The work around in our case is to modify the inner layouts Presentation layout mode to Inline-block. Please try and let me know.
Shanthini Charles
Capgemini
below work around is not working...
"The work around in our case is to modify the inner layouts Presentation layout mode to Inline-block."
Techmahindra
Hi Pandj,
Shanthini Charles
