capgemini
Last activity: 28 Feb 2018 22:42 EST
Light weight list has been copied in rule
Hello All,
In Data Transform, I used Append and Map To and setting few properties. In the logs, i am getting the exception as under :-
additional frames in stack;*NA*Light weight list has been copied in rule '@BASECLASS PXCALLDATATRANSFORM #20130919T003938.431 GMT Step: 1 Circum: 0' 4001 times. Property Reference : D_SCDiagnoseQuestionnaire_pa227fc4472e3279597b0f6d47f486143dpz.pxResults(51)<CR> Stack Trace: java.lang.Exception<CR> at com.pega.pegarules.data.internal.clipboard.VirtualClipboardPageImpl.considerVLCopyAlert(VirtualClipboardPageImpl.java:2146)<CR> at com.pega.pegarules.data.internal.clipboard.VirtualClipboardPageImpl.considerVLCopyAlert(VirtualClipboardPageImpl.java:2053)<CR> at
When searched in PDN, i found that we need to Modify prconfig setting alerts/virtuallists/copy to false. I went through all prconfig settings available in SMA but don't see this option.
Did anyone encounter similar exception while using data transform rules ?
What is the meaning of this exception and how can we avoid it ?
Any leads are appreciated.
Also, view additional information in the above provided links. It has detailed explanation.
