Great Eastern
SG
Last activity: 24 May 2017 22:57 EDT
JVM called WLS shutdown hook. The server will force shutdown now
Weblogic server is auto shutdown during listener run. below is log copied from pegarules log.
Kindly advice solution for this problem.
PRPC Version :- 6.3
Weblogic :- Proprietary information hidden
JAVA :1.6
<May 22, 2017 11:41:57 PM MYT> <Notice> <WebLogicServer> <BEA-000388> <JVM called WLS shutdown hook. The server will force shutdown now>
<May 22, 2017 11:41:57 PM MYT> <Alert> <WebLogicServer> <BEA-000396> <Server shutdown has been requested by <WLS Kernel>>
<May 22, 2017 11:41:57 PM MYT> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to FORCE_SUSPENDING>
<May 22, 2017 11:41:57 PM MYT> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to ADMIN>
<May 22, 2017 11:41:57 PM MYT> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to FORCE_SHUTTING_DOWN>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "DefaultSecure[2]" listening on xx.xx.xx.xx:xxxx was shutdown.>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "Default" listening on xx.xx.xx.xx:xxxx was shutdown.>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "DefaultSecure[1]" listening on xx.xx.xx.xx:xxxx was shutdown.>
PRPC Version :- 6.3
JAVA :1.6
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "Default[1]" listening on xx.xx.xx.xx:xxxx was shutdown.>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "DefaultSecure[3]" listening on xx.xx.xx.xx:xxxx was shutdown.>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "DefaultSecure" listening on xx.xx.xx.xx:xxxx was shutdown.>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "Default[2]" listening on xx.xx.xx.xx:xxxx was shutdown.>
<May 22, 2017 11:41:57 PM MYT> <Notice> <Server> <BEA-002607> <Channel "Default[3]" listening on xx.xx.xx.xx:xxxx was shutdown.>
