Job schedulers replace Advanced agents
Job schedulers replace Advanced agents, we have upgraded our application form 7 to pega 8.2.5 version.
Can Job schedulers also use queueing if done explicitly? How to achieve this?
My requirement is I need to replace the Advance agent with the Job scheduler, in 7 versions we configured Advance agent to process the records for every 30 seconds in the queue.
As I said i need to replace with Job scheduler I am not able to see the seconds tab for excepts hours and minute, PFA for reference.
Can someone please suggest on this requirement.
As you already know, you can run a job scheduler multiple times a day. However, for Pega Platform 8.1 through 8.4, currently, the only options are run After every N minute(s) or After every N hour(s), where N is an integer that specifies the delay before starting the next run -- i.e., run After every N second(s) is not currently supported.
I hope this helps.
