Incessant Technologies
Last activity: 9 Feb 2017 6:38 EST
javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
I am facing this exception when a REST Service is inokved. We are using pega 7.2 version.
Can anybody help me on this?
Hi Kishore,
Please have a look into the following PDN article and see if it helps.
https://community.pega.com/support/support-articles/restful-services-fail-sslpeerunverifiedexception.
Also refer the below link for similar discussion.
https://collaborate.pega.com/question/we-are-getting-following-error-while-invoking-rest
Thanks othos.
Sure i will follow in those groups.
Hello Kishore ,
SSL peer unverified exception can caused by multiple reasons .
Are you using oneway SSL or twoway SSL ?.
Which application server your using ?
What is the PRPC version used at your end ?
Is the certificates are working before ?
Have you imported the certificates to trust store ?
Provide us the complete stack trace of this exception to have a look into the issue .
Arun
Hi Arun,
We are using TLSv1.2 protocol.Am not sure about 1 way or 2 way SSL.
We don't have any certificates as such for current service which i found issue with.
And server we are using is Tomcat. and we are using Pega 7.2 version.
Hi Arun,
com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_1df02d5a96ad215dc3e7350d2a9c98bf.step6_circum0(ra_action_pyinvokerestconnector_1df02d5a96ad215dc3e7350d2a9c98bf.java:1771)
at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_1df02d5a96ad215dc3e7350d2a9c98bf.perform(ra_action_pyinvokerestconnector_1df02d5a96ad215dc3e7350d2a9c98bf.java:154)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510)
at com.pegarules.generated.activity.ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.step7_circum0(ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.java:1002)
at com.pegarules.generated.activity.ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.perform(ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.java:172)
at com.pegarules.generated.activity.ra_action_pxcallconnector_11f2ec27fb0b16bb79951eb7d74cbe15.step10_circum0(ra_action_pxcallconnector_11f2ec27fb0b16bb79951eb7d74cbe15.java:1664)
at com.pegarules.generated.activity.ra_action_pxcallconnector_11f2ec27fb0b16bb79951eb7d74cbe15.perform(ra_action_pxcallconnector_11f2ec27fb0b16bb79951eb7d74cbe15.java:246)
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runRule(DeclarativePageDirectoryImpl.java:1010)
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runLoadActivity(DeclarativePageDirectoryImpl.java:437)
at com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.loadDataPage(ReadOnlyDataPageHandler.java:246)
at com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.findDataPage(ReadOnlyDataPageHandler.java:430)
at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.findDataPageInCurrentDir(AbstractPageDirectory.java:924)
at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.getDirectPage(AbstractPageDirectory.java:717)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getDirectPage(ThreadPageDir.java:471)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:429)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:421)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.getPage(PRThreadImpl.java:539)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getTopPage(PropertyReferenceImpl.java:2169)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getTopPage(PropertyReferenceImpl.java:2113)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.resolveEmbeddedPages(PropertyReferenceImpl.java:1789)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGet(PropertyReferenceImpl.java:1368)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGet(PropertyReferenceImpl.java:1348)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGet(PropertyReferenceImpl.java:1332)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.get(PropertyReferenceImpl.java:1168)
at com.pega.pegarules.session.internal.mgmt.Executable.getProperty(Executable.java:2304)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.getProperty(StreamToolsImpl.java:821)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.getValue(StreamToolsImpl.java:883)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.getStringValue(StreamToolsImpl.java:966)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.compareTo(StreamToolsImpl.java:1164)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.equalsConditional(StreamToolsImpl.java:1192)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.evaluateSide(StreamToolsImpl.java:1375)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.orConditional(StreamToolsImpl.java:1479)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.multipleCondition(StreamToolsImpl.java:1499)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.evaluateCondition(StreamToolsImpl.java:1533)
at com.pega.pegarules.generation.internal.stream.StreamToolsImpl.evaluateWhen(StreamToolsImpl.java:1627)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.evaluateWhen(AutoStreamRuntimeImpl.java:1019)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.generateClientWhenDiv_2(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:26012)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.simpleLayoutCell_2(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:26172)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.simpleLayout_1(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:26206)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.pzLayoutBodyWrapper_1(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:26000)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.pzLayout_1(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:26226)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.pzSectionBody_1(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:794)
at com.pegarules.generated.html_section.ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.execute(ra_stream_mcrmainscreen_4e423c52e19bc629378e02184ef06a4a.java:103)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:4043)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3871)
at com.pegarules.generated.html.ra_stream_reloadsection_001d5c66ba807400c0ecb484e9d2fe6f.execute(ra_stream_reloadsection_001d5c66ba807400c0ecb484e9d2fe6f.java:192)
at com.pega.pegarules.pub.runtime.AbstractActivity.showHtml(AbstractActivity.java:247)
at com.pegarules.generated.activity.ra_action_reloadsection_2fa9990d2c3a50dc1363126cee2ec1a1.step8_circum0(ra_action_reloadsection_2fa9990d2c3a50dc1363126cee2ec1a1.java:900)
at com.pegarules.generated.activity.ra_action_reloadsection_2fa9990d2c3a50dc1363126cee2ec1a1.perform(ra_action_reloadsection_2fa9990d2c3a50dc1363126cee2ec1a1.java:188)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:466)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3093)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390)
at sun.reflect.GeneratedMethodAccessor80.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1277)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1015)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:848)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:817)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:327)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:270)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:247)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
at sun.reflect.GeneratedMethodAccessor75.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
at org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcessor.java:188)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2517)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2506)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
at sun.security.ssl.SSLSessionImpl.getPeerCertificates(SSLSessionImpl.java:421)
at com.pega.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:128)
at com.pega.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:398)
at com.pega.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:496)
at com.pega.apache.http.conn.scheme.SchemeSocketFactoryAdaptor.connectSocket(SchemeSocketFactoryAdaptor.java:62)
at com.pega.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:148)
at com.pega.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:149)
at com.pega.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:121)
at com.pega.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:573)
at com.pega.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:425)
at com.pega.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:825)
at com.pega.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:759)
at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_1df02d5a96ad215dc3e7350d2a9c98bf.step6_circum0(ra_action_pyinvokerestconnector_1df02d5a96ad215dc3e7350d2a9c98bf.java:1296)
... 103 more
2017-02-08 13:40:00,465 [ ajp-apr-8009-exec-8] [TABTHREAD0] [ ] [ EAOSApp:01.01.01] (nvoke.Rule_Connect_REST.Action) ERROR kmittapalli - com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
2017-02-08 13:40:00,465 [ ajp-apr-8009-exec-8] [TABTHREAD0] [ ] [ EAOSApp:01.01.01] ( internal.mgmt.Executable) ERROR kmittapalli - Exception
... 103 more
Hello Kishore ,
Can you please follow below article and let us know if it helps .
Arun
Hi Kishore,
PeernotAuthenticated exception will involves multiple issues. To get to know the exact cause, need to add below JVM argument while startup and get the server logs. There ssl handshake information will print.
-Djavax.net.debug=ssl:handshake:data
Aruna Pyla
@KishoreKumarM3328 - I agree with 'pylaa' here: the SSL DEBUG logs will show the picture more clearly; trouble-is the SSL debug logs are very verbose; so I think you need to find out more about the requirements of the endpoint in question here.
- for instance when you say:
You need to get somebody who can tell you this for sure - 2-way SSL implies approximately twice the complexity needed for configuration. (You need two Certificates, two keypairs etc. : one on server, one on client).
Have you got an example of another (non-prpc) client that IS able to use this remote endpoint ?
Perhaps even just a browser ? (Can you point your browser at the endpoint ? Do you get any Certificate errors/ warning in that situation ?)
