National Australia Bank
Last activity: 1 May 2023 4:29 EDT
java.lang.NullPointerException triggered by ApplicationSetup OOTB activity
Hi, we have observed in our log files, that lot of EXCP0001 alerts are being logged .
On further analysis we have found out that a Null pointer exception is occurring from ApplicationSetup OOTB activity .
Can anyone help me out when this "ApplicationSetup" rule will be triggered and what could be the reason behind Null pointer exception.
Thank you!!
PFB sample log
Thank you!!
PFB sample log
2023-04-26 08:34:29,620 GMT*8*EXCP0001*0*0*329b50b0447d90526ba831a9a7985e07*NA*NA*BG2ZFN58WZFVHSWYTB8AO6NCGD9L0FSUFA**NAB-UWF-Work*NUWFAPP:03.01.01*345d41a035f33ce6991cedd580ce24fb*Y*1*BG2ZFN58WZFVHSWYTB8AO6NCGD9L0FSUFA*6565*PegaRULES-Batch-94*STANDARD*com.pega.pegarules.session.internal.mgmt.Executable*NA*PegaSocial-Message.pyPublishUpdates*Rule-Obj-Activity:ApplicationSetup*CODE-SECURITY APPLICATIONSETUP #20190618T110028.910 GMT Step: 2 Circum: 0*NA****NA*NA*NA*NA*NA*NA*doActivity Rule-Obj-Activity:ApplicationSetup;initial Executable;0 additional frames in stack;*NA*[MSG][Exception][STACK][java.lang.NullPointerException<CR> at com.pega.pegarules.session.internal.authorization.SessionAuthorization.setShrinkJavaScriptEnabled(SessionAuthorization.java:1142)<CR> at com.pega.pegarules.session.internal.authorization.Authorization.setShrinkJavaScriptEnabled(Authorization.java:1680)<CR> at com.pega.pegarules.exec.internal.PRExecThreadStateImpl.setShrinkJavaScriptEnabled(PRExecThreadStateImpl.java:641)<CR> at com.pega.pegarules.exec.internal.PRExecThreadStateImpl.setShrinkJavaScriptEnabled(PRExecThreadStateImpl.java:630)<CR> at com.pega.pegarules.session.internal.mgmt.PRThreadBase.setShrinkJavaScriptEnabled(PRThreadBase.java:802)<CR> at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.setShrinkJavaScriptEnabled(PRThreadImpl.java:1845)<CR> at com.pega.pegarules.exec.internal.basic.staticcontent.StaticContentUtilsImpl.setShrinkJavaScriptEnabled(StaticContentUtilsImpl.java:1971)<CR> at com.pegarules.generated.activity.ra_action_applicationsetup_728c6cf2e3b3b3389581b32afc6ce7ce.step2_circum0(ra_action_applicationsetup_728c6cf2e3b3b3389581b32afc6ce7ce.java:467)<CR> at com.pegarules.generated.activity.ra_action_applicationsetup_728c6cf2e3b3b3389581b32afc6ce7ce.perform(ra_action_applicationsetup_728c6cf2e3b3b3389581b32afc6ce7ce.java:93)<CR> at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2814)<CR> at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:653)<CR> at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:580)<CR> at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:511)<CR> at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:304)<CR> at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:360)<CR> at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1158)<CR> at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1397)<CR> at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1140)<CR> at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1021)<CR> at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:818)<CR> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)<CR> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)<CR> at java.lang.Thread.run(Thread.java:750)<CR>]*
