Marsh
Last activity: 18 Jul 2017 10:50 EDT
Issues with launching the excel file using tools.sendFile API
I am having issues with launching the excel file using tools.sendFile API. I am using the tools.sendFile(buffer, "compare.xls", false, null, true) to launch an excel file.
I have verified the buffer content and its completely alright. In the fiddler the content type is coming as application/octet-stream. In another scenario where I was able to launch excel from non-pega url, the content type is coming as application/vnd.ms-excel.
Is there an issue with the way, i am using the tools.sendFile API? I cant see any error in log or something like that, but the file is not launched, nothing happens.
Code below
/*Creating byte Array by reading excel file*/
java.io.File objFile = new java.io.File(tools.getParamValue("filedest"));
java.io.DataInputStream dis = null;
byte buffer [] = null;
try
dis = new java.io.DataInputStream(new java.io.FileInputStream(objFile));
buffer= new byte[dis.available()];
dis.readFully(buffer);
dis.close();
dis = null;
catch (Exception e)
throw new PRRuntimeException("Can't retrieve file attachment. Can't read File",e);
Code below
try
dis.close();
dis = null;
catch (Exception e)
finally
if (dis != null) {
try {
dis.close();
} catch (Exception ex) {}
tools.putParamValue("length", buffer.length);
/*calling sendFile API of Pega*/
String sErrorMessage = tools.sendFile(buffer, "compare.xls", false, null, true);
if (sErrorMessage != null){
tools.getThread().getThreadPage().putString("pyXMLStream", sErrorMessage);
pega.terminateActivity();}
***Updated by moderator: Lochan to close post***
