Techmahindra
Last activity: 2 May 2016 12:27 EDT
Issue with Date property using in the Case match rule
Pegasystems
When I click on your first picture, it pops up but doesn't get any bigger, so I can't see your error message. I'm curious, did you paste it with firefox ? If you use a file to put picture in first, does it make it work better ? /Eric
Techmahindra
Techmahindra
I am still waiting for solution. Please help us in resolving the issue.
Thanks & Regards
U Rajasekhar
FR
Techmahindra
Hi Marc,
We are using Pega 7.1.7.
Thanks & Regards
U Rajasekhar
Techmahindra
Could someone provide solution.
Thanks in Advance.
Best Regards
U Rajasekhar
FR
I tried the same configuration on Pega 7.1.7 and I can save the rule as expected. Can you try to recreate it from scratch with just the "Date" property and nothing else.
Techmahindra
Thanks Marc,
We will try creating new date property and update you.
Could you please share the steps you followed to test? It will help to compare.
Best Regards
U Rajasekhar
Techmahindra
Hi Marc,
Could you please share the steps you followed to test in Pega 7.1.7? It will help to compare.
Thanks & Regards
U Rajasekhar
Techmahindra
Hi Marc,
Thanks & Regards
U Rajasekhar
FR
Well I haven't done much really:
1) Create a date property called "TestLassmDate"
2) Create a case match called "CaseMatchLassm"
3) Add the property into the case match and save the rule.
Techmahindra
Thanks Marc......
