Virtusa
Last activity: 25 Jun 2023 22:27 EDT
Issue with data page having source as report definition
Hello People :)
I came across a issue with below configuration
- I have a report definition, this report definition is having a column FullName, this FullName is calculated using declare expression(FirstName+LastName). When I run the report I am able to see FullName column properly.
 - But, Now I am using this report definition as a one of the aggregate source for my data page. And I have a response data transform to map results from report definition to data page. When I run this data page, FullName is getting as blank even though it is mapped properly in response data transform.
When I traced this scenario, I found that FullName is being blank on DataSource pagelist even though values are available in the db. So, there is an issue when I use a column which is calculated declaratively and used as a source for data page.
Everything works fine if I give FirstName and LastName as columns in report definition :>
Is this an expected behavior or some weird issue :O
Thanks in advance :)
