TCS
TCS
TCS
Posted: Dec 14, 2023
Last activity: Dec 23, 2023
Last activity: 23 Dec 2023 9:53 EST
Datapage-unable to use report definition as source with page structure
Hi Team
I have created a datapage with source as report definition. that report definition is retrieving from data type.
It works fine if I select datapage structure as list for single record retrieval and multiple records retrieval.
but if change the datapage structure to page and tried to retrieve single record, it is not working.
Could you please help on this?
***Edited by Moderator Rupashree to add Capability tags***
@Anoop Krishna Thank you Anoop. As you mentioned, RD returned results instead of page and it was under the data page. It worked after changing the Data page-object type class from data table class to 'Code-Pega-List'.
