Invalid certificate error while building mobile channel
We have recently obtained credentials for Pega Mobile Client. I can build an Android app using signing certificate which I generated using java keytool. But I can not build with the certificate I got from Google Cloud Console. I have used APIs & Services > Credentials > Create Credentials > Service Account Key .p12 in order to get the certificate.
Any ideas why do I get the Invalid Certificate error on Designer Studio ?
Can you compare certificate type for both the scenarios.I believe the one which you generated using keytool is of .cert type and the one you got from google cloud is .p12 format.Please generate certificate in same format and give a try.
Abhinav
